It is currently Fri Aug 08, 2025 5:53 am
 Post subject: What cutters do you use?
PostPosted: Mon Jun 29, 2009 3:10 pm
hi all
I have ordered a Virutex Laminate Trimmer with a 1/4 inch collet and was wondering what sizes and shaped cutters are most commonly used in guitar making, dovetailed necks, binding, rosette, end graft, head shaping and anything else I’ve missed.
Geordie
some tunes on acoustic and guitar synth.
http://www.youtube.com/user/TheGeordieAdams
http://www.myspace.com/geordieadams
PostPosted: Mon Jun 29, 2009 3:32 pm
for 1/4 inch .. 1/4, 3/16 adn 1/8 downcut spirals, solid carbide, as well, 1/4 bull nose, i use both a 2 flute carbide and a 4 flute end mill. If you dont have a specific binding setup, you may also need one of the binding cutter sets form either stew mac of LMI
get a 1/4 to 1.8 adapter, and then you can use a host of 1/8 inch shank bits too .. like the smaller 1/16 and 3/64 for inlay (although i now much prefer the mini die grinder air powered for that.
PostPosted: Wed Jul 01, 2009 10:54 am
Many thanks Tony
I'll see if they do an 1/4 to 1/8 adaptor.
What about dovetail bits, size/angle?
Geordie
PostPosted: Wed Jul 01, 2009 11:21 am
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
You'll have alot better luck cutting dovetails with a bigger router, and a bit with a 1/2" shank.
I use a Porter Cable 7518 router with a 5/8" template guide and a CMT 818.658.11 dovetail bit. The bit has a 1/2" and is 5/8" diameter with a 7 degree angle. I'm sure other stuff works too.
Users browsing this forum: ChuckB, Ken Lewis and 25 guests
